1999 Dyna Wide Glide. Carbureted engine. Stock coil. Bike will crank over but will not run. No spark at plug wires. Center wire of wiring harness that plugs into coil is hot when switch is turned on. Anyone have any ideas what should be checked next.
Bike was running well when put up. It has sat about two months before I tried to crank it. Battery is hot, was on auto charger. All other electrical system work fine. Thanks for your input.
cy
cy
