Paint remover removes paint by producing heat which causes the paint to lift, I dont think it would produce enough heat to lift the chrome, but I would try putting paint remover on some piece of chrome a test piece to see if any damage to the chrome occurs, also be careful to cover any areas or painted surfaces this stuff drips and has a way of getting into unwanted areas,and do damage and if you dont coat it heavy enough it wont produce enough heat to lift the paint, water neutralizes it for cleaning but be sure to wash it off thouroly with soap and water, making sure to hose down thouroghly run off areas, finally I would chemically clean off any areas with a rag soaked not dripping with laquer thinner to get rid of the residue left behind, before starting any final sanding or prep work, I dont know how bad the affected areas are but I would consider sanding smooth and re painting only because the area your in is a tough place for consequential damage to occur from the paint stripper.
