Stock Pipes
Discussion in 'Dyna Models' started by lnichols2, Dec 12, 2007.
  1. lnichols2
    lnichols2 Member
    5
    i have a 93 FXDWG that when i got it had a set of BUB pipes.and i want to go back to the stock pipes BUT i cant seem to make heads or tails about what brackets to use on the trans to support
    the pipes.the brackets that i see in the parts books only show 1 bracket but it doesnt have anywhere to mount to the bike just to the pipes.and i dont think the exhaust studs will do the trick alone. anyhelp !! Thanks Les
  2. Not Very PC
    Not Very PC R.I.P
    527
    Lay your stock pieces all out on a floor or table where you can photo all of them (1 photo of all parts together ) will do. and I'll do my best to guide you through it. If you number the parts in the photo it'll be simple.
  3. glider
    56
    [​IMG]
    Here's the 93 FXDWG exhaust breakdown
  4. lnichols2
    lnichols2 Member
    5
    Thanks for the breakdown it was helpful.but the parts are discontinued that i need. Les
  5. glider
    56
    Have the dealer check stock in other dealers to see if they are lying on the shelf somewhere. They can do it through the system if they aren't too lazy.
