Re: Steering head maint/fall away adjustment
Ok, I'm kind of disgusted by the approach in the manual for my '07 Super Glide. I'm doing the 1,000 mile service.
I removed the clutch cable from the perch on the lever, and there seems to be a little drag caused by the throttle cables, but not a lot. The manual says to loosen the fork stem nut, and the lower tree clamp bolts. Then you adjust the bearing preload with the star nut to get 2-4 inches of fall away measurement..
I'm not sure how to tighten or loosen the star nut since it is under the top tree. I'm thinking using a screw driver or a punch, and a hammer to tap/spin it. You can't remove the top tree since it is holding the fork tubes. I don't understand why you wouldn't just loosen the top tube clamps while adjusting the preload and let the bottom clamps hold the tubes. Then you could get the top tree out of the way and allow access to the star nut.
I don't understand why they don't use a bearing preload method such as an auto front hub with a castle style nut lock and cotter pin which would be much easier.
