starting help
Discussion in 'Sportster Models' started by Pnrdrmmr, Jul 20, 2009.
  1. Pnrdrmmr
    Pnrdrmmr Member
    7
    I just purchased a Sportster today, it is a 1993 frame and suspension and a 2000 evo 1200 motor. The guy I bought it from said he was on the freeway when it started acting funny, and thought that the diaphragm in the carb had a hole in it. We replaced the carb with a good one and got new sparkplugs for it. It is getting spark and slightly turning over, it will run for a few seconds then die, but it will blow out black smoke when it starts. I live in Utah and the guys at the HD shop said the jets were to big, I don't remember the size tho, so could it be that its running to rich to start? I'm not very savvy with engine work at the moment, so I don't really know what is wrong with it. Any help would be greatly appreciated.
  2. Pnrdrmmr
    Pnrdrmmr Member
    7
    Okay sounds good. But what is the enricher? and where is it located.. I'm not to savvy right now. But I can figure it out when pointed in the right direction. Thank you very much tho.
  3. NEWHD74FAN
    8,191
    98
    19
    Here is a link to get you going on how to dissect the carb components and how they fit into the circuit at various throttle openings.
    http://www.hdtimeline.com/fuel_and_ca...rb_models.html
    Here is Glider's rough carb circuit chart
    [​IMG]
    Here is an exploded view of the stock HD Kehein CV Carb:
    [​IMG]
  4. Pnrdrmmr
    Pnrdrmmr Member
    7
    Ok, the enricher/choke seems fine, moves nicely. The jetting on the original carb is 170/45. Should I go smaller on those or are they fine? I would run some treatment thru, but we can't get it to start at the moment.
