I took a ride the other day and when I came out my 02 Road King started and then shut off. It runs for about 3 seconds and the quits. I hear the efi kick in went switched to run but thats it. Any idea's? Thanks Torg
Torg It could be a number of things such as bad gas (water) or even a broken injector wire right near the plug on the injector. They were notorious for that. Do the wire wiggle test when it is running and see if the engine cuts out when you wiggle the injector wires near the plug on the injector, usually within an inch or two of the plug. You didn't say if the lights go out when this happens but there is also a breaker problem in those year bikes too, it's been upped to a 50 amp from 40. Could be a engine sensor or even the fuel line inside the tank. http://www.hdtimeline.com/fuel_and_carb_related_issues/979-engine_dies_at_half_a_tank.html Do you hear a hissing coming from inside the tank when it pressures up? Does the fuel pump recycle the second time if you let it sit a minute? Do you get any flashing lights in the speedo while running or after startup within seconds indicating a fault code? Have you checked for spark at the plugs? Are the plugs wet with gas? Here's how to check for a code on that bike. http://www.hdtimeline.com/diagnosti...elated/729-00_03_hd_codes_and_activation.html It's difficult or even impossible sometimes to diagnose a problem over the internet without complete information when this happens. Look for more symptoms like explained above and post back again.
I'll do these checks first thing in the AM. Thank you very much...speedy too! I think I'll be spending alot of time on these threads this winter..plan on putting on some apes. Thanks for the heads up on that 50 amp fuse too did not know that one. Thanks again Torg
OK.... I got her started, I checked all the wires and the plugs and she fired up. But after running the engine light comes on after the 4 seconds and stays on for about 7 to 8 seconds. I was going to take for a ride today and see what happens with the trailer on stand-by. Torg
