Stage One
Discussion in 'Touring Models' started by xdanman, May 30, 2010.
  1. xdanman
    xdanman Member
    60
    Most people are doing a stage one With SE backplate. I like K&N filters.
    Could I not replace stock filter with KN and get as good breathing as the SE?
    I dont want to do the SE and then replace it with KN. I really dont like SE
    filter.
    There's a replacement K&N filter for the stock filter but the inprovement in flow isn't that much in the stock filter housing. The SE model is a taller model for more flow.
  3. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    xdanman; go for the full stage-1 b/c the filter's only one part of this UG. Back plate, breather ports & inlet are also modified to enhance air intake & increased flow. Also, don't forget to add a tuner so you can change settings b/c bike's already run lean from factory - gott adjust for the added air.
    Might be a good time to change the look of your A/C & add some personal style - I went w/LA Choppers xXx breather & really like the look/performance. Only advice is to check clearance - I had to extend floorboards out 1" so my Right thigh didn't hit the A/C (thanks Harley Goodies).
    Good luck & let us know what you choose.
  4. xdanman
    xdanman Member
    60
    Thanks, That is exactly wat I wanted to know.
  5. sprinkman
    sprinkman Active Member
    114
    I have a stage 1 SE air filter installed. Should I change the old football cover to get more air flow?
  6. glider
    With the taller filter there's no need to change the cover other than looks.
