squeak up front
Discussion in 'Other Service and Maintenance' started by lowrider13, Jun 5, 2016.
  1. lowrider13
    lowrider13 Active Member
    113
    I have a 04 RK classic, lately I am getting a noise when bike is warmed up that sounds like a chirping noise 0r rubber against rubber maybe. I went I hit a bump it seems to be heard. It doesn't seem to do it when first out , but later in the ride it appears. Any help would be appreciated.
  2. joel
    joel Senior Member
    1,024
    126
    I had an 03 RKC and had a squeek / chirp sound.
    Ended up being the rubber insulators on the rear mount for the mufflers. When up to temp and the noise is happening put your boot on the end of the muffler to see it it changes.
    roadking96 likes this.
  3. TQuentin1
    4,737
    142
    I think Joel has you covered. I had the same problem on my '03 UC. Kept trying to oil/lube it which would work for a few weeks and then the noise would return. I finally just bit the bullet and replaced them with new isolators. Problem solved. I guess the elastomer just gets hard after a while exposed to high temps.
    Cheers,
  4. lowrider13
    113
    Went out and jiggled the left exhaust and it does squeak a bit. I will change them out and hopefully this will end the noise.
  5. Jeff Klarich
    4,792
    103
    484
    If you end up changing the rubber mounts pay attention how they come out so they can be installed the same way. Mounts can be put in backwards if you're not paying attention.
  6. HDDon
    5,542
    133
    229
    I'll be nice and not ask you how you know.
    Jeff Klarich likes this.
  7. Jeff Klarich
    4,792
    103
    484
    Exactly.
    HDDon likes this.
  8. TQuentin1
    4,737
    142
    I think we have all done that!!
    But good point Jeff.
    Cheers,
    HDDon and Jeff Klarich like this.
  9. Jack Klarich
    The rubber in the muffler mounts need a bit of lube once in a while, Silglide works good
    Bodeen likes this.
  10. joel
    joel Senior Member
    1,024
    126
    On a trip once while the noise was chirping away, I stacked a couple pennies between the rubber and the plate. Tightend it up good and noise was gone.
