sputtering
Discussion in 'Electrical' started by muttman, Dec 10, 2011.
  1. muttman
    muttman New Member
    97 Roadking 67,000 miles, starting hard backfire thru carb cold or hot also loss of power. I think its my ignition coil but not sure, also not sure how to check coil help:newsmile058:
  2. Dr. Dolittle
    6,404
    118
    29
    Would this help?
    Harley Davidson Community
  3. Jack Klarich
    Welcome to the Forum, Harley Davidson Community Have a look here and other pointers in the self help section. The C V carb is cold blooded and lean from the factory, Doe pulling the Enricher out help? If it does you may want to rejet:s
  4. glider
    How long have you owned this bike and what has been done to it other than stock?
    Has it always done this if you have owned it a while?
  5. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    Some 96 and 97 model year bikes had problems with the hall effect sensor under the cam cover that tells the module when to fire the coil. One of the symptoms is a back fire thru the carb.
    My 96 dyna had one that would go static at the weirdest times, hot, cold. while riding, while idling, it made no sense. I managed to troubleshoot it when it happened one day. This was after the HD dealer had 2 under warranty "Could Not Duplicate Malfunction" services. With no problem found, I had to pay the shop time.
    I took it to the dealer and they change the sensor. Problem fixed.
  6. glider
  7. HDDon
    5,542
    133
    229
    If it just started this and pulling the enricher helps you may have a leak in the intake side. The rubber coller that seals the carb throat to the intake manifold may need to be replaced. Or the carb itself is loose.
