sputtering then stalled
Discussion in 'Engine, Fuel and Exhaust' started by killertiki, Feb 16, 2010.
  1. killertiki
    killertiki Member
    25
    Hi guys,just bought a 2002 883 sportster,cruising home, and it sputtered a little wouldnt get any speed, and then died,wont start up again,the bike sat for a while before i bought it, am new to harleys, but assume its a carb thing,its got gas wants to start,just doesnt, just checking to see what you guys think?
    carbs?
    50
    Drain the tank and put some fresh gas in it for starters. Possibly have to clean the fuel strainer in the petcock.
  3. killertiki
    killertiki Member
    25
    its got new gas, drove it a couple days, ran good, did notice a little sputter a once or twice
  4. sharpscuba
    sharpscuba Banned
    945
    DITTO on what Glider said. I wouldn't start to mess with the carb just yet.
  5. killertiki
    killertiki Member
    25
    Have to give a shout out to my new bud Dave, who passed by me broke down,spun around and asked if i needed help,drove his bike home and got his trailer,and trailered my bike home for me, making him late for work, the brotherhood rocks!!!!
  6. glider
    50
    You also may try draining the carb with the drain screw at the bottom. Sometimes the sediment or water will pool at the bottom of the float bowl causing a problem. Try to catch what drains out from the drain tube in front of the rear wheel to verify if there was any gunk in there.
    Look at this post.
    *Poor Performance With Carb Models - Harley Davidson Community
  7. killertiki
    killertiki Member
    25
    just read that in the help section, thanks glider, will try that tomorrow
  8. Chopper
    Chopper Senior Member
    1,632
    19
    It does sound like a fuel problem, you might also take a look at the vacuum line that runs to the fuel valve just to make sure it's on there good.
  9. NEWHD74FAN
    8,191
    98
    19
    As most have stated, starving for fuel could mean simple foul gas, debris in the float bowl, obstructed inlet filter, cracked vacumn line or bad inlet fuel valve diaphram...! Funny thing is I have owned six bikes and have had or seen all of them before. I seem to recall somewhere that sometimes troubleshooting is something to be saved for the young...its late and time to get some shuteye for this old timer...:small3d007:
  10. killertiki
    killertiki Member
    25
    all fixed up, it was the spark plug wire, where it plugs into the box, had a bad connection, runs great now, thanks all.
