nascar7613
speedo problemns
I am swapping a electronic speedometer on a 97 fatboy. The current speedo has different electrical connections then the replacment has. I bought a kit from harley to change the connectors, but I don't know how to arrange the wires in the new connector. I haven't been able to locate a wiring diagram of the connector. Any ideas?
Thanks for the manual. Let me ask you this. Sometimes the odometer will come on. When the odometer works, the speedometer works, and vice versa. I replaced the vss and have the same problem. I assumed the speedo head was probably bad. What do you think?
