TripleJ
Senior Member
Thanks. That is exactly what happens, headlight gets bright then I would loose the spedo for a few seconds. I am in the process of checking the voltage reg out. Last night I checked the charging system, and it was ok. Checked Stator and it was also good. :newsmile108:
The problem with testing the VR is it could be such an intermittant problem that it may or may not show up while testing. If no other problems are found more than likely the VR is the issue.
