I installed a set of these to assist with brake pad changes, bleeding the brakes or flushing the brake fluid. Very simple to install. Have everything very close by, and ready to go. Remove the existing bleeder valve, and about 1 table spoon of fluid will escape. Install speed bleeder and tighten to requirment, do not overtighten or you will snap one off in the caliper. Bleed that Brake, move to next brake.
Turned a two person job into one I could do by my self. Plus, I no longer need to figure how to get fluid out of the master cylinder to install new brake pads. Just open the speed bleeder with a hose into a suitable container to catch fluid, push brake pad back into the caliper. Close speed bleeder. After changing the pads top off the fluid, and pump the brake pedal until firm. top off as required.
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
