Someone help me find out if this is a real motor and what kind if so
Discussion in 'General Harley Davidson Topic' started by Tomasini727, Aug 1, 2016.
  1. Tomasini727
    Tomasini727 New Member
    I have this table made of a harley davidson motor is am told .. can anyone help me identify the motor or info if anyone has seen this before
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    It certainly looks like a real engine. It's an "Evolution" made from 1984 - 2000 (for certain models). It could be a hollow block, or fully functional. If you can lift it by yourself, it's probably a model.
  3. TQuentin1
    4,737
    142
    Would be a serious waste for someone to use what looks like a "new" EVO to make a table. As Breeze said above, if you can lift the engine part of the table by yourself without some serious grunting and risk of a hernia, then it is probably not a working engine. That doesn't mean it is not engine parts, it just means that the guts may not be there.
    Take the air cleaner cover off and see what is behind it. If there is a filter element, and there is a carburetor behind the backing plate, then it is starting to suggest that it may be real.
    Where did you get it? If you bought it, how much was it (ballpark)? A new working EVO is gonna start around $2,500 depending on displacement and go up from there. So if you bought this "table" for much less, then someone did not know what they had, or it is not a working engine.
    Let us know what you figure out. Got our curiosity up!!!
    Cheers,
  4. Jack Klarich
    Very popular seller @ events like Sturgis a few years back
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Looks like a REAL EVO to me... Made larger and had a look... Carb is there and too much Normal Engine looks front and back...
    With table ? about 90 to 100 lbs?
    Get her Running...
  6. dbmg
    dbmg Guest
    What ever it is that is one cool table...:cool:
