Softail DTC identification question
Discussion in 'Softail Models' started by marchrisco, Oct 11, 2008.
  1. marchrisco
    marchrisco New Member
    4
    I'm trying to locate the meaning of diagnostic trouble codes P0371 and P0372 that I retrieved from my speedo earlier today.
  2. marchrisco
    4
    Thank You Sir.
  3. glider
    50
    P0371 0r 0372 are crank position sensor but listed for 04-06 sportsters.
  4. glider
    50
    Me either, recheck the codes again.
  5. marchrisco
    4
    I double checked the codes. They are P0107, P0371, P0372, and P0563 in that order. My bike is a 2004 Heritage Softail Classic w/carb.
  6. Bud White
    3,270
    P0107 Map Sensor Failed Open/Low Carb
    P0563 Battery Voltage High Carb
    AS for the other 2 i dont see them listed any where
  7. marchrisco
    4
    I had located both of those already in another post as well. Thank you for your effort.
  8. Bud White
    3,270
    im betting it is still a crank sensor code.. does it run ?
