Slip on exhaust
Discussion in 'Engine, Fuel and Exhaust' started by ksheritage, Oct 9, 2010.
  1. ksheritage
    ksheritage Member
    30
    I am thinking about adding Vance and Hines Slip On Exhaust to my 2007 Heritage Softail Classic. If this is the only modification that I want to make now, do I have to add a tuner or can I just change the mufflers? Thanks.
  2. dbmg
    dbmg Guest
    I second that. Only with muffler change may notice drop in fuel mileage. This is caused by excessive use of right wrist while enjoying sound of your bike.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    +1 on that, and +2 on Smitty's reply.
  4. Jack Klarich
    Agree with all of the above:p
  5. Chief1948
    Chief1948 New Member
    3
    Would this also be true with a 2008 Road King Classic?
  6. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    I'm sure and it would be true for any model. The more you twist the wick, the quicker the tank empties. :D
  7. wilks3
    wilks3 Junior Member
    623
    Vance & Hines make great slip-on mufflers. Cycle shack has a large selection also. Go to a local bike gathering and listen/ask what other guys are running. If just slip-ons used probably won't need fueler. There many different ways to richen up fuel mixture.
    Check out the Dobeck TFI section.
    wilks3
    :USA
  8. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Also, when replacing pipes, make sure you get a new set of pipe clamps & HT silicone (liquid copper) for a good seal. Want to make sure there are "0" leaks.
  9. Chief1948
    3
    Thanks guys!
    One more question, is there any mod available for stock slash cuts to make them more noticeable?
  10. glider
    Aside from drilling the baffles...NO. The sound after drilling the baffles will make you go out and buy new mufflers in any event.
