Shovelhead engine numbers?
Discussion in 'General Harley Davidson Topic' started by steamdonkey, Jun 10, 2010.
  1. steamdonkey
    steamdonkey New Member
    3
    Greetings All
    I'm new here to the sight and looking for a little help.
    A few days ago, a friend of mine bought a HD shovelhead.
    The bike is registered as 98 "custom / build bike" by the state of Washington .
    I'm trying to figure out what model year the motor is.
    The numbers on the case don't seem to match any thing I can find on the various identifcation tables.
    the number on the right case "located near the front pushrod tube, reads as follows 3561924 8 676 the number do not have a space between them as I have them here " I did this because the 8 seems to have stamped with a different die. in reality it somewhat like a "infinity" symbol.
    thanks for any help ahead of time.
    Steve J
  2. TQuentin1
    4,737
    142
  3. Jack Klarich
    Those do not look like factory numbers, if this is a Recon bike when first registered a lot of states want certificates of origin for frames, motors and trannys, may try to back track that to find out for sure, Got any cop friends, they may be able to help:s
  4. blademan
    blademan Active Member
    179
    All shovels that I have ever seen have the numbers on the Left side of the case about center below the barrels.
  5. fxst1450
    fxst1450 Member
    9
    :unsure Cops as friends?
  6. glider
    Sure, just give them some doughnuts :lolrolling
  7. hogrotten
    hogrotten Junior Member
    642
    5
    The vin#,s on the older bikes are not the same as post mid 80's bikes. I would suggest calling hd cust. service, I called about my brothers 79 lowrider and they were very helpful. :D
  8. Jack Klarich
    They want money now mo more do nuts LOL, but seriously if you have any cop friends and we all should have at least one they can help you track the previous owner usually alot easier than the DMV:D
  9. Jack Klarich
    Thats where The Mo CO stamped them:s
  10. kmac
    kmac Member
    i agree with blademan all shovels i've seen have the numbers left side case
    and yes its always good to know a cop or two and the county sheriff not bad either
