free website stats program short | Harley Davidson Forums
short
i have a 2005 Electra glide classic and it does have led around the trunk at times it will blow the 15 amp fuse on the tailghts i have traced the wires from the fuse box all the way back to the rear lights also removed the trunk plate and trunk found no wires cut could it be the led lights i have check the wiring harness under the rear fender it has no rubs any help would be appreciated thanks mac
I'm thinking water intrusion at a splice somewhere. Check the splices and redo them with solder and shrink tubing and a little silicone on the edges of the shrink tuning.
Bodeen
Check with a multi meter, you may find a break in the middle of the wire harness
