Shifting problems on 97 ultra
Discussion in 'Transmission' started by lnovander, Jun 15, 2013.
  1. lnovander
    lnovander Member
    5
    At first it was hard to get into neutral. Then about 3oo miles ago it started not to down shift. It felt like something was locked in place. If I double clutched it then it would down shift. I asked my mechanic what he thought it was he said maybe clutch needed adjusting. I did this and adjusted the cable. Didn't help. Still wouldn't down shift. Will only go into neutral when motor is off. Now while moving it sometimes won't shift into higher gear. What might could be the cause of all these problems?
    The bike has 70,000 miles on it does the clutch pack need to be changed?
  2. lorne
    lorne Senior Member
    2,428
    58
    22
  3. Jack Klarich
    Welcome to The Forum, check the shifter arm on the side of the tranny, see if it has loosened up
  4. lordharold
    lordharold Active Member
    191
    you adjusted the cable free play did you also adjust the clutch adj screw?
  5. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Does the shift lever still have spring pressure when you try to move it both up and down? If there is not spring pressure in both directions, the shift pawl spring has broken.
