shifting problem ..
Discussion in 'Transmission' started by hdultra2010, Aug 22, 2014.
  1. hdultra2010
    hdultra2010 Member
    64
    well, after i got my new bike , 2010 hd ultra classic with 19000 m, i saw a leak in my garage the first weekend after purchasing it. put new oil in all holes, check the belt, cause i bought from a shop without warranty. after investigation the stator was leaking , so i checked all forums , and put prematex but still sipping just litle, . rode the bike for 90 miles , came back and notice that shifter shat seal has oil there .
    anyway , went to stealer got new stator and shifter shaft seal with bearing seal and new bolts.
    yesterday start tearing her down and couldn't grab the the assembly (primary chain, compensating sprocket and clutch assembly), so i used the 3 jaw on clutch assembly and voila, took the whole assembly out, the inner ...change the seal on shifter shaft, change the bearing seal on the inner put new stator, bolt it. put everything back together as the service book stated. adjust the belt , and the clutch lever.
    I didnt put any oil on primary yet. but tried to shift while on stand, it shift from first to second , i can go back neutral but i cant shift to the 3rd and up. then thought i might tight too hard the clutch adjuster , no help either, took off the shifter link and tried to shift just by hand on shiter , same thin , it shift up to second...:(
    what i did wrong? can someone help me plz. thanks
  2. Bodeen
    4,647
    73
    221
    Clutch adjustment is the first thing that comes to mind. Maybe the ball came off the ramp on the end if the clutch cable?
  3. hdultra2010
    hdultra2010 Member
    64
    was thinking to open the transmission cover and check there, but want to make sure that i didnt do something wrong or need some adjustment on primary that i dont know about. thanks
  4. Bodeen
    4,647
    73
    221
    If you have the service manual, check primary chain tension and adjust clutch by the book. What happens then?
  5. hdultra2010
    hdultra2010 Member
    64
    the primary chain tensioner is automatic , it adjust itself as soon i ride it
  6. dbmg
    dbmg Guest
    You will find that most motorcycles regardless of brand with out running you may only get a couple of gear changes and not the full shift pattern. So quite possible you have done nothing incorrectly other than filling oil and starting bike up.
    Check this out:
    Harley Davidson Forums
  7. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    Double check the adjustments, get your fluids right, start it, check for leak and then see what happens. If everything looks good, ride and see what the transmission does. What dbmg says is true.
  8. hdultra2010
    hdultra2010 Member
    64
    ok guys, will fill it up with oil and see what happen, thanks again.
  9. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    You are moving/spinning the rear tire when trying to shift aren't you?
  10. hdultra2010
    hdultra2010 Member
    64
    NO i didnt spin the rear tire at all till i find out it wont shift and adsjust the clutch second time, then i did spin it after that to make sure i was in Neutral :)
