Posted by "Bud White"...
Not a Hard one to do but i figures i'd snap a few pics and post it up
There is the stock one .. thin ugly and has weak ball joint linkage
Remove the old one
Pic of new one and old one .. Fatter Chrome and Heim joints
I set the prelength the easy way
Now if i need to adjust some I'm at least in the ballpark
Here it is installed don't forget to loctite the bolts
Doesn't really do much other than look good and less chance of the linkage popping apart esp if you use the rear shifter
Yes that is frost on the Primary 16 Degrees today
Remove the old one
