At the moment I'm not going to get the Stage 1 mod but I want to down load my original MAP. I havent pluged it in yet because my a@# puckers every time I get ready to plug it in because I feel like I'll loose my ORG map. I would like to modify the ORG map to get my AFR down to around 14.2:1. Is this possiable?:eam
You can't download your map from the ECM. If you use one of the canned maps off the disc (I'm pretty sure you can find one close), then max out the CLB table, you will get your AFR down around 14.2
