Hi Jack. Please don't misunderstand me, I have no argument that hot or colder plugs can allow or alleviate pre-ignition. That has been going on since the days of no ECMs or fuel injection. A hot plug (as long as it doesn't get too hot) can keep carbon burned off for round town driving since carbon build up will cause pre-ignition of the worst kind. Where as a cold plug for more highway or race environments will run cooler where carbon build up is not so much a problem.
Now I know you already know all this. But this whole ion data based on per-determined conditions is still a bit much for me to swallow that the plugs are a large issue given the other attributes going on much more often that plug changes.
I'm not familar with the SE plug nomenclature as to its hot or cold (tip configuration) or it's internal resistance. But I will accept that you say it caused knock and don't doubt it a bit. As to "why" it caused the knock, well that's still another story. One thing I feel for sure, if a plug can break the ECM's ability to overcome knock buy corrupting pre-determined running conditions, then "most" of our bikes already have stuff to do the same or more.
