screw in tire
Discussion in 'Softail Models' started by ggold, Apr 26, 2007.
  1. ggold
    ggold New Member
    4
    noticed a screw in front tire of springer classic it is not leaking now, I'm headed to leesburgh tomorrow, should I plug it, leave it and forget about it or change tire, it is a new tire. I understand the risk.
  2. rayhdavidson
    rayhdavidson Member
    23
    Plug it with a repair plug kit. Unless you have gone already. Ha!
  3. Not Very PC
    Not Very PC R.I.P
    527
    Change the tire, live to ride another day.
    I carry a plug kit on trips and have used it, but kept speeds below 35mph till I got to a shop for a replacement.
  4. glider
    56
    Springer classic...
    You have spokes on that...no?
    Can't plug tires on spokes, they have a tube.
    Some patch/replace but for safety sake I would replace it.
    Plugging should be a temp fix to get you home in any event and there should be a replacement tire on the way.
    Unlike cars that have 4 wheels, bikes are less forgiving when a damaged tire takes an early retirement while you are riding.
    What cost would you put on your life as opposed to the cost of a new tire?
  5. Not Very PC
    Not Very PC R.I.P
    527
    There we go I never thought about the Spokes :hii
  6. glider
    56
    That's why were BOTH here :D
    Slept good last night, the gray matter is working today.
  7. Not Very PC
    Not Very PC R.I.P
    527
    I worked in the shop most of the night making dyno pulls & writing a new map for a friends Fatboy, He bought a Jims 120 and sent it to Branch for Pro street build. Made 165hp & 156ftq at 6400rpm on 93 pump gas.
  8. glider
    56
    That's some nice healthy numbers for sure.
    More HP than TQ?
  9. Not Very PC
    Not Very PC R.I.P
    527
    Huge cams and ports. If this wasn't a "B" motor numbers would be better. But a 6500rpm limit stops that.
    It didn't start coming on the cam till 4000rpms.
    I would have chosen 60G cams instead of the 64Gs he used.
  10. glider
    56
    Agreed, 4K is a bit high to start working. How much is anyone going to constantly ride over 4K to utilize the power.
    B motors spinning 6500....eeeeeeeowwwww
