luther johnson
i just recently purchased a 2000 harley davidson fxds lowrider convertible.
and the other day it started puking oil out of air breather and blowing the oil fill cap off. so right away i knew i had a blow by problem. so first i check the unbrela valves i changed them out and it was still doing it. so next i tore the top end off and found out it had screaming eagle pistons in it. and when i pulled the jugs off i found out that both pistons were broke in between the rings luckily didn't scare up the cylinder walls but when i was looking the jugs over i noticed that the bottom of the jug had a o-ring instead of a paper base gasket. my ? is can i use the regular gasket kit or do i have to order the gasket kit from Harley for the screaming eagle kit the regular kit has a paper base gasket and the harley kit has o-rings
