BOBFLHTC
I took my S&S carb off to rebuild my Top end and stored it on its side. When I went to put it back on my bike gas was flowing liberally from the Overflow tube when I turned the gas on. When I dropped the bowl to see what the problem was the Valve that is controlled by the Float was out of position. So the take away is if you remove your carb store it in a upright position. The good news is was a easy fix - Bob
