S/E Compensator
Discussion in 'Touring Models' started by badge171, Nov 17, 2010.
  1. badge171
    badge171 Member
    31
    Bought my S/E compensator and locking tool today for my 09 Street Glide , any help, or tips on the removal or installation is greatly appreciated , Thanks
  2. dbmg
    dbmg Guest
  3. badge171
    badge171 Member
    31
    Thanks much I will give it a try this weekend.
  4. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    I did mine and it wasn't a big deal. I didn't have to remove my clutch as the chain was long enough so that made things easier.
  5. Dr. Dolittle
    6,404
    118
    29
    Use the search function of this forum and you should find lots of helpful threads and posts.
    Main challenge for me was getting the old compensator bolt off. Make sure you have a long breaker bar for this and the locking tool in place. Then use a torque wrench to put everything back on.
  6. Jack Klarich
    Compensator Kit - Harley Davidson Community This may help
  7. HardyHarHarley
    HardyHarHarley Member
    7
    I just changed mine out to the SE Comp last weekend in my '09 Street Glide. Unless your side casing is different than mine, you will not be able to remove the rotor. This is due to the ridge on the inside of the casing. Your options are: loosen or remove the inner casing; or grind the lip away providing clearance for the rotor. I chose to grind.
    Be sure to protect everything from the metal shavings and clean up afterwards. I used a vacuum as well as a magnet to remove all shavings.
    Now that the casing is clearanced so the rotor can be easily removed, the job can be done in less than an hour from start to finish.
    I was able to remove the Comp without removing the clutch. I did remove the spring tensioner. That left enough slack in the chain to be able to slip the Comp sprocket off the shaft and back on.
    Good luck.
    Jim
