Rusted gas tank
Discussion in 'New Member Introduction' started by HARLEY1063, Jun 3, 2014.
  1. HARLEY1063
    HARLEY1063 New Member
    I have run into a problem with my 97 Ultra Classic. The tank rusted bad inside and the pump will not come out. I do have a company that can get rid of the rust then i can get the pump out, But how strong is the bracket that holds the pump in place I'am hoping that it will cause no problems. The only other thing i have been told is to buy a new tank and insides at a cost of about $3,000.00.
    I hope someone will have a better answer.
  2. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    There's lots of motorcycle salvage yards, and ebay that have compatable tanks for WAY less than you were quoted. As for how strong the brackets inside your tank are, not real strong. Tanks are thin metal, if the rust inside is so bad bolts are frozen, it may be about through the paint in some areas.
  3. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,805
    133
    197
    Welcome aboard, glad to have you here. :ws
  4. Jack Klarich
    Welcome to The Forum, I would buy a factory manual ASAP
  5. ciscokid
    ciscokid Member
    72
    fill tank with sand river sand about 1 gallon w seal it up wrap in heave blanket , put into dryer, (make sure its completly wraped good and stuff things in dryer so it wont move,,,, VERY IMPORTANT...DO NOT turn dry on to hot setting , use the cool down setting. tumble for a couple three four times check tank.. works for those rusted tanks. but its easier to just buy one off flea bay
  6. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    Welcome!
  7. ciscokid
    ciscokid Member
    72
    so did you get it figgered out yet ..............
  8. r_k_dragon
    r_k_dragon Active Member
    270
    4
    So, how's that tank situation coming along and welcome to the forum from the southwest desert.
  9. Sunnysideup
    Sunnysideup Junior Member
    527
    4
    I've used red apple cider vinegar before and it worked very well given at least two days to sit and work. Need to fill it completely to the neck though. Also as soon as you drain it, be sure to wash it out with gas to stop the flash rust that will happen. A tank sealer would probably be good once you get the pump out.
