Running Too Lean
Discussion in 'General Harley Davidson Topic' started by colder, Oct 28, 2006.
Thread Status:
Not open for further replies.
  1. colder
    colder New Member
    hello,
    How do you know if your bike is running too lean? I've heard that you could end up with holes in your pistons...Will a dino test tell me?
    Colder
  2. DYNAGUY
    DYNAGUY Active Member
    123
    The 07 are running on the edge. You dont want to change nothing on them without getting fuel remap.:D
  3. Not Very PC
    Not Very PC R.I.P
    527
    Welcome! What Model and year bike are we talking about?
    Modifications?
    Your gonna know you've got a problem way before you burn a hole in a piston. When you accelerate is it smooth or ruff with popping and backfiring? Spark plugs will be the easiest to read at home, they should be a light tan color, Black is rich, white is lean.
    And yes a Good Dyno Tuner can use a Dyno to tell if your motor is lean.
  4. glider
    56
    Pssst guys, did you look at the date on the origional post:D (over a year ago):hii
    I'm sure by now he probably burnt a hole in the piston.
  5. csmlopez
    csmlopez Member
    66
    PC is absolutley correct. Look at your plugs, they will tell the story: white is lean, juicy black is rich and heroin light brown is correct.
  6. dangerdan
    dangerdan Junior Member
    922
    I just checked colder's profile ....that was his one and only post.
    Oopsies
  7. blackmouth
    blackmouth Member
    52
    Well...he probably decided he wouldn't enter his 2nd post until he got an answer to his first! :D
    Soooo....the 2nd post should be coming right up!
  8. Not Very PC
    Not Very PC R.I.P
    527
    I just figured he was in another time zone :D
  9. glider
    56
    Yeah....outta time:D
  10. Speed
    Speed Site Tech Administrator
    2,945
    Lets say this problem has been solved,so we can close the thread now guys.Thanks for all reply :)
Thread Status:
