Hello, I have a 2017 Street glide special that recently started running pretty rough and spitting in burnt fuel out the exhaust. It is only running on the rear cylinder, when it initially started I had codes for the injector in #1 cylinder, p0261 and 262. I checked the plugs to the injectors and they were fine. So far I have replaced the injectors, coil, plugs and wires. Compression test on both cylinders and they are within spec, all 4 plugs are getting spark. I rode the bike the day before it started and had no issues, the morning it started I started the bike to let it warm up, ran for about 5 mins before I left, I pulled out of my driveway and went 20 yards and it started running very rough and the check engine light came on. I’m not sure what else it could be, it’s getting fuel, spark and has compression yet when I start it up it only runs on the rear cylinder.
