rotor runout tolerance?
Discussion in 'Wheels' started by cyberfish2, Jul 21, 2010.
  1. cyberfish2
    cyberfish2 Member
    35
    While I had my '09 Street Glide on the rack to change the oil, I spun the front wheel and noticed a slight drag on the rotors in one spot. I have a metal lathe, so I mounted the rotors, and measured the runout - .006 on the right one and .002 on the left one. Stock rotors are double disk ground hot rolled steel plate (I was a tool&die maker for 40 years). I mention this because rotors are easily deformed. They should be removed during a tire change to prevent being bent.
    Careful tweaking reduced the .006 to .002, not perfect, but better. I'm pretty sure I can use them like this without too much additional wear on the pads, but I'm wondering if anyone knows what the runout tolreance is?:bigsmiley28:
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Thanks for that info. How do you have that lift set up in your garage? Looks like a hoist and table? Nice working height.
  3. EnjoyingTheRyde
    EnjoyingTheRyde Junior Member
    467
    5
    I brought mine in for a check and 1 was .008 and within HD tolerance but the other was at .012 and they replaced it... I've been told by my indy that stock rotors are junk. Time to do more reading regarding alternatives.. In any case, that much out makes for very difficult slowing... especially at slow speed...
  4. cyberfish2
    cyberfish2 Member
    35
    Harley Davidson Community
    I started out with a motorcycle floor jack, but it got in the way for oil changes, and seemed a bit unstable.
    I built the stand out of 1" angle iron, welded all the joints, and cut wood 2X4's to fit wherever needed for the top of the stand.
    I spanned two of the rafters with two 4X4's braced in with long screws, and put a long eye bolt in the center, thru the ceiling, so I could attach a chain hoist. To be on the safe side, I welded the eye bolt where it circled around to meet the shaft.
    I have 4 nylon straps to lift the bikes, two for the handle bars, and two fit around the top of the shocks.
    This is a very stable, fairly versatile, setup. I put Fumoto valves in place of the oil plugs, so changing oil just takes attaching a hose, and turning the valve handle. The oil filter is easier to get to with the stand, and I have both wheels clear for tire changes.
    I'd be happy to post more detailed pix if there is any interest.:D
  5. Bodeen
    4,647
    73
    222
    My question is. What is the runnout of a brand new HD rotor? My bet is that its not pretty.
    Having said that, Smitty posted some time ago about using the HD floating rotors and he was happy with them (try the search above). Other brands are very pricey and Chinese also. Russell makes a reasonably priced, albeit Chinese, rotor.
    I like to see your lift setup. Very curious indeed.
    Bodeen
  6. EnjoyingTheRyde
    467
    5
    Ya like I said, I need to study the differences and figure out what to do because mine seem to be out again... I have had some close calls with brakes ON... We'll see...
