Here's the Andrews roller chain upgrade for the engines that now run the problematic cam chain tensioners. It replaces the old style tensioners with the hydraulic chain tensioner used in the newer 96 TC engines.
This conversion eliminates the cam chain tensioners that wear away and disintegrate with the final result in damaging the engine.
http://andrewsproducts.com/PDF_files/Cams88_99-06chain.pdf
