Will the front rocker box assembly fit on the rear cylinder of a Twin Cam motor and the other way around?
The gaskets are the same, always use new gaskets, one side is marked front & other side rear if I remember, just set them up like in the picture below. Also I don't try to change parts from one cylinder to the other, I like to keep all parts in same position as when I took them off, so push rod ends go back into the same rocker cups, just habits I guess.
