roadglide starting issues
Discussion in 'Touring Models' started by tperry, Aug 25, 2010.
  1. tperry
    tperry New Member
    My 2007 roadglide has issues with starting. Sometomes it starts fine 30%-40%, some times it grinds but starts 30% - 40%, othertimes there is a knarley nashing and it stops turning over and does not start. The bike is 100 % stock with 42K miles. There was a service bulletin on this stating to look for signs of arking at ground points. I have pulled the starter, cleaned all mating surfaces to inner primary and ground cables with grinder / scotch pad. no help. pulled starter 2nd time and opened primary to inspect gears all look good. This bike NEVER started nice/ smooth like any of my other bikes.You can feel it engage in the seat of your pants.
  2. mnultra
    mnultra Active Member
    293
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    The compensator is what came to mind when I was reading your post, especially when you say you can feel it in your seat.
  4. Hoople
    Hoople Account Removed
    7,198
    34
    Could also be too much slack in primary chain or not the correct backlash in the starter pinion to ring gear clearance. I have seen that clearance raise some Terrible sounds and noise on cages. If the noise happens that often, just drain the primary and take off the primary cover. Disconnect the plug wires(grd them) and crank it through. Your not going to hurt anything and the noise should stand out. It may help you locate the source of the noise.
  5. Jack Klarich
    Seems to me 07 was the year of the new starter and ring gear problems, mine made a lot of noise and broke the ring gear, The Stealer told me they have had a few problems with 07 models:s
  6. Z-Man747200
    Z-Man747200 Member
    15
    I second this post! My 07 has had more than it's share of starting issues and the Ring Gear has broken twice.
  7. glider
    50
  8. glider
    50
    :lero
  9. HDDon
    5,562
    133
    236
    So not only are you quick and always have the information at your fingertips, now your making sneek attacks.:newsmile100:
    How are you doing guy?
  10. glider
    50
    I'm doing, just not happy with the accommodations.
