RK Battery Dead
Discussion in 'Touring Models' started by sprinkman, Oct 10, 2010.
  1. sprinkman
    sprinkman Active Member
    114
    Does anyone know how or if you can pull codes from a RK. Friend has a 2003 RK and battery goes dead after a couple days of sitting. He says he has installed 2 different batteries the last couple years. If he rides it is good for a couple days and then goes dead he said battery tender ruined his other batteries. Sounds like some kind of short to me need help!!!
  2. Jack Klarich
  3. sprinkman
    114
    Thanks Jack, Will the codes tell if there is a short?
  4. Jack Klarich
    No, you will have to start at the battery and work your way thru each system. I would check the voltage at idle first should be at least 13 volts and load test the battery, a dead short there could be the whole problem, Good luck and let us know, there is a lot of help here for you, Hoople is MR. Electricity, if he cant help no one can, Capital Jack
  5. sprinkman
    114
    Thanks Jack, My friend is a trucker will be back late in the week and we will take a look nat it then!!
  6. NEWHD74FAN
    8,191
    98
    19
