ok what I have done is check the bulb, the wires to the tail light. and the fuses and as far as I can tell it's all good but I still have no right rear turn signal... any ideas ?
Did you check for the ground to see if it was there on that light also try a new bulb. Also take a look under the fender at the wiring, there has been a few that the tire rubbed through the wiring harness there.
Check to see if the light housing is grounded like it should be? Other than that, get out the test light and see where you are loosing the power in the harness by opening it up at the plugs under the tank.
