Replacing tank badge
Discussion in 'Softail Models' started by Keithhu, Nov 23, 2009.
  1. Keithhu
    Keithhu Active Member
    133
    How are they attached? More double stick tape?
    Curious if anyone has replaced their tank badges (without other major tank mods/paint), and if so, what method works well.
    Whats the best place to find replacements?
  2. 01 Night Train
    01 Night Train Member
    7
    If you are removing the 3-D metal tank badges it is easy. They are held on by double sided tape. You can warm them up with a hair dryer. Then use dental floss to "slice / cut" trough the tape (take your time). Once the badge is off you will have some residue left. You could use prep-sol or other mild cleaners on a cotton rag to help remove the residue. I would wash the tank thoroughly after using any non-standard cleaner on it. The process is pretty easy and just takes a few minutes to do it right.
    I hope this helps.
  3. TQuentin1
    4,737
    142
    I have had VERY good luck getting adhesive off my tank using a clean rag soaked in WD40. I just placed the rag over the spot and soaked it with WD40. After a bit, ALL the adhesive wiped off. I was pleasantly surprised at how easily it came off.
  4. glider
  5. biscuit
    biscuit Junior Member
    591
    25
    There's a huge number of badges on e bay.You should be able to find what you want by typing in something like:Harley tank badges on ebay or:Harley tank emblems on e bay.
    Give it a shot.:s
  6. Keithhu
    133
