removing tssm for tsm
Discussion in 'Electrical' started by jimmyc, Nov 27, 2008.
  1. jimmyc
    jimmyc Member
    hi to all...new to site and hope you can help me not spend some money. took out a tssm module from my 08 sporster and replaced it with a standard tsm. is there a way to reprogram the ecm to not see the password from the tssm. the bike will start them die after releasing start switch. dealer says i have to reprogram. i need backwards from the answer you have in the alarm section for marrying a tssm into a bike. thanks for any info. happy bird day to all.
  3. jimmyc
    jimmyc Member
    glider, thanks for the response. i saw your answer for adding a tssm to a ecm from scratch but was not sure if it would work taking off a tssm and putting back a standard tsm. that's what i meant by "backwards"....that i need the instructions for doing the opposite that everyone seems to be doing. i want to remove the alarm. anyway, thanks again, i'll give it a try in the a.m. have a good night!
  4. TQuentin1
    4,737
    142
    Don't forget to put a battery charger on while you are doing it. With the system having to go through the "on" mode for all that time and with lights, camera, action all on, it can drag down the battery.
  5. glider
    OK that makes sense now. You should need to do the password relearn then. Any time a component like this is removed and replaced with another one, they have to "talk" to each other in order for the bike to run. The relearn procedure is just that. It makes the components communicate.
  6. jimmyc
    jimmyc Member
    glider,
    just wanted to let you know your instructions worked like a charm! bike is running and i'm 50 bucks richer....untill i find something else to buy. thanks again for the help and the site is a great help. hope to repay the favor one day. till next time, jimmy
  7. glider
    Good deal jimmy. Glad you're up and running.:s
