trickydoc
bad front wheel bearings in the ultra. got the wheel off and have a blind hole bearing puller. I think the bearing has spun inside the wheel. puller will not remove it. before I apply heat to my wheel, (cast spoke tubless type). will this heat discolor or damage my wheel. anyone have any experience with this. right bearing will turn with some difficulty, cannot manually turn the left bearing. neither will come out. getting ready to add the heat, just wonderiing if it will kill my wheel. thanks. tricky
