regulators
Discussion in 'Classic Models' started by peepawandy, May 19, 2010.
  1. peepawandy
    peepawandy New Member
    4
    I've switched the 6v system to a 12v system on my 59FLH and was wondering if I can use the Bosch type regulator on my bike.
  2. Jack Klarich
    Dont forget to flash the regulator, when you are done it polarizes the system:D
  3. ultrat
    ultrat Senior Member Contributor
    1,315
    i personally did not.. but a friend did w/ he changed.
  4. NEWHD74FAN
    8,191
    98
    19
    Newer technology means precautions are needed, 12V system basically was set up for starting improvements...more reserve voltage to fire ignition while starter is off loading the battery surface charge...but once running, ballast resistor switches in to run ignition on 6V to preserve points during normal operating mode.
    Further modernizing will require other changes of course, but the key is to remember that 12V systems are more efficient...requiring smaller guage wiring and ultimately lighter weight and more "reserve" power to run more AND COMPATIBLE modern accessories. If you are not building a 100% original machine, a hot rod with nostalgic looks but modern technology makes for a better daily driver...congratulations and cheers to a successful build.
  5. Jack Klarich
    Never been a big fan of Bosch, but it will work, dont forget to reflash every tme you dis connect the battery, good luck:s
