regulator question
Discussion in 'Electrical' started by 67shovelbucket, Apr 15, 2011.
  1. 67shovelbucket
    67shovelbucket Banned
    50
    hello all, my new question is this, if you have a generator with a regulator on the end of it. do you still have to run a voltage regulator?
    Why would you need an additional regulator?
    The regulator on the end of the generator should handle the charging load.
  3. War Horse
    War Horse Member
    95
    If you have the 3 wire aluminium end regulator, thats it . All ya need.
    1 wire to battery.:D
  4. War Horse
    War Horse Member
    95
    If I remember correctly, the stock big regulator mounted to the engine boss just forward of the distributor.
    Tbones, the reg .I was refering to was the solid state ones with the ally finned body, forget who made em, but had one on my pan for 14 years with out any problems. But I also had a police 3 brush generator, that I rebuilt once.
  5. 67shovelbucket
    50
    didnt think it needed 2 regs but i am taking off the generator end to see what it is , it might just be a end plate. there was however just one wire from the a side connected.the old reg was taken apart and made into some sort of fuse box.hmmm anyways thanks to you all. ill be back later with most likely more question.
  6. Jack Klarich
    Polarizing A Generator - Harley Davidson Community each time you disconnect a battery or generator
  7. War Horse
    War Horse Member
    95
    There it is, thanks Jack , it was driving me nuts trying to remember the name of the reglator I had. A Franks.....:newsmile108:
  8. Jack Klarich
    My pleasure, a lot of folks do not know this about Generators:s
