Redhamster212
Hi Mate,
I have a HD 1993 FXRS-C 08/93, my problem is starting, the first time I hit the starter it makes a load click and I release the button straight away, then try again and it will crank over (Most Times), I have listed some details of the bike below and all electrical has been checked and battery load tested (Fully Charged Twice);
Starter: 1 week old, bought 1.4kw to replace original OEM to fix this problem
(Problem Still There) after $500 bucks
Battery: CTX20-BS; Load Tested Twice and result was (275cca) under load test
Battery Float before start: 12.98 vdc
Bike was second hand so do not know all that has been done to it,
Compression (Cold) 170psi each pot), this confirmed by bike shop
Cam: Andrews EV27
Valves: Noisy
Starter Relay was Changed with New Starter Motor
Ignition: Standard
I do not know what is going on but any help to fix this would be welcomed,
Regards
Greg Cousen
(Lurchy)
Cam: Andrews EV27
Valves: Noisy
Ignition: Standard
Regards
Greg Cousen
(Lurchy)
