red key on
Discussion in 'Electrical' started by brightlights66, Jun 9, 2013.
  1. brightlights66
    brightlights66 Member
    6
    red key came on, no power to speedometer, tach, horn, stop and turn lights, starts and runs ok, all fuses ok.
  2. Slo-Ryd
    Slo-Ryd Junior Member Contributor
    527
    23
    Sounds like a speedometer bus error which may just be a loose, wet or dirty connection. Have you tried pulling any codes yet? Check the attached link below.
    Harley Davidson Forums
  3. turnerbend
    turnerbend Active Member
    231
    38
    3
    Check your security system...
  4. brightlights66
    6
    tried to do the reset, didn't work, I am going to take the switch on handlebars
    apart tomorrow, check wiring in them.
    it seems to be working ok, I ordered a manual so I can trace
    No codes coming up.
  5. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    Did you check the fuses with a meter? They are so small that a blown fuse can be missed, I've done it.
  6. brightlights66
    6
    All fuses check good.
  7. brightlights66
    6
    Seems like all the functions that are not working, have one thing in common........a ground,
    i will start looking for a open in a ground circuit.
  8. Breeze3at
    4,921
    224
    Did you also check the fuses under the right side cover? They are for the ECM and FI, but I think one is labeled P&A. The ECM has to be unpluged to get to them.
  9. brightlights66
    6
    Well, I went back and checked the fuses again, this time with my VOM on ohms, the assory. fuse showed a problem, I pulled it out of panel and , there it was a blown fuse, next time I will pulled them out of circuit to test. replaced fuse, ran codes, found only one code, cleared it and now, things back to normal. But I didn't find the problem, I guess checking and moving wires and plugs around, must have hidden the problem, now for the road test, see if it blows fuse again.
