Rear tire wear
Discussion in 'Wheels' started by cowpoke, Jul 23, 2016.
  1. cowpoke
    cowpoke Member
    42
    Noticed a little more tire wear on the left side of the rear tire, not the extreme left , but the left just past center of the tire.
    I have several K mile on it so whatever it is it isn't extremely wrong.
    My first guess is that the rear axle might need some adjusting. Just trying to determine which way to go with it.
  2. dbmg
    dbmg Guest
    Have you checked that rear wheel alignment is proper in swing arm?
  3. Jack Klarich
  4. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    It could be normal for the area in which you live/ride. Most roads have a crown, Northern roads more so than Southern roads.
    The crown can make a tire wear slightly more on the left.
    gator508 and Jack Klarich like this.
  5. Jack Klarich
    How true Pete, we are called flat landers now LOL, I try to find sweeping country roads to even out my tire wear
  6. cowpoke
    cowpoke Member
    42
    Thanks for the info/tips
    Just to double check, if it weren't anything else (bad road, not aligned with front tire)
    then I assume it would be the rear adjustment of the tire ie. left to right (some bikes have notches or other method to
    keep left and right side at the same # of turns etc.) but not this one 1999 Softail custom.
    Back to my original ?
  7. dolt
    dolt Senior Member
    2,172
    103
    333
    If the wheel is not aligned, it will show when you measure from the center of the pivot shaft to the center of the axle; the distance should be the same on both sides. If it is, axle adjustment is not the problem. Could be you just got a bad tire.:eek:
    Get the service manual for your bike; best tool in the box.;)
