Rear tire repair
Discussion in 'Softail Models' started by fatboysteve, May 17, 2010.
  1. fatboysteve
    fatboysteve Member
    8
    Went to take my new fatboy out and noticed I had a flat rear tire(400miles on bike). Found a screw in the middle of the tread pattern. Can this be fixed by taking off tire and patching from the inside of the tire. I've done this with car tires not sure if its safe for a bike. Going into dealer to have fixed. THANKS for responses
    That's a bummer, but I would replace the tire. On a bike you only have 2 wheels and a repaired tire could cost you your life.
  3. stefdustin
    stefdustin Member
    87
    I agree, I have plugged them on the road but changed them as soon as possible. Its just like good insurance..............
  4. hobo55
    hobo55 Active Member
    306
    Be safe change it asap. We have a bad enough time out there with the weather,roads,animals and idiots.
  5. Jack Klarich
    H D does not recomend tire repairs I would replace it as soon as you can, I have limped them home with a plug but do not rely on this or a patch JMO:D
  6. pigrider
    pigrider Active Member
    110
    I'd repair a tire or patch a tube only to get me to where I could get a new one, not only is a safty issue but you will never have peace of mind knowing you're ridin on a repaired tire.
  7. NEWHD74FAN
    8,191
    98
    19
    FatboySteve, I would use a Stop & Go Plug Kit (should carry one w/ CO2 inflator as a pre-caution as you never know what can happen on a trip) and since you are "home" just use old fashion bike pump and air it up...
    http://www.stopngo.com/motorcycle.asp
    OR as Hobbit said use the aerosol Tire Inflator/Repair Sealant (the latter is disliked by tire changers because of the gooey mess)...just long enough to ride it to your dealer/tire repair servicer. As Glider said, you only have two wheels, and when one deflates suddenly, bad things can and often do happen.
  8. RAWLDYMAN
    RAWLDYMAN Active Member
    151
    18
    Have been checking out these kits and was goin to start a thread to get some views but since the subject is already under discussion.....
    does one of those little cannisters really inflate the tyre sufficiently to get you going again?...just seems so small! Does it give you a decent psi in your tyre?
    Also, does the cannister nozzle fit all tyre valves? or do you need some kind of adaptor?
  9. fatboysteve
    fatboysteve Member
    8
    Thanks for all the input guys. I will have the tire replaced it's not worth the risk. Does anyone need a really good tire for a burnout contest? LOL
  10. NEWHD74FAN
    8,191
    98
    19
    In a nutshell yes, get the one with 3 or 4 cannisters (just in case), the CO2 refills are cheap (the larger ones are better of course). You can also get the basic one with small electric inflator if you are worried as some have done if you do not believe in using "new tech"
