OEM pads come with detailed instructions, but as Bulldog said a manual is invaluable, keep it clean and lube the pins per the instructions and bleeding them is a good idea, buy only the amount of fluid you will need, once opened the fluid will start taking on moisture, good luck and check back in, Capital Jack
