I have a radio static problem with my '86 Tour Glide. It's related to the rotation of the front wheel? For each turn of the front wheel, there are four equally divided double clicks of static on the radio?
1)Does the problem Only happen when using FM?
2)Are you using the factory antenna and is the antenna mounted in the usual rear storage compartment (tour pac). And is it sticking straight up.
3)Was the radio installed after the bike was purchased.
4)Is it the typical radio that would be installed for that year bike.
5)Did you add any "boosters" to the antenna.
6)Did you modify or change the height of the factory antenna.
7) Was the PRESENT system ever working correctly with no static.
8) Does the static increase in volume as you increase the volume control or is the level of static remain constant regardless of volume pot position?
One more question.
9)Have you disconnected the speedo cable from either end and still get the noise.
i have an 07 ultra and the rear headphones are contantly cracken and making static.
BroncoBob, Did not mean to high-jack your thread but the wheel static problem really got my attention.
I don't have tunes on my bike so bear with me.
1) On the rear, does the headphone jack use a 1/4" RCA Phono plug or does it use a 7 pin DIN plug?
2) Do you hear the static change or does it get worse when you adjust the rear volume control.
3) As long as you are not moving (with engine off also) can you listen to the rear headphones static free?
The closest schematics I have are for a 2009 Ultra. On that year there are rear speakers along w/ rear headphones. The rear also has their own volume control. Is that what you have.
Do you have a service manual for your exact year & model bike?
