radio shack siren
Discussion in 'Touring Models' started by razor10, Mar 23, 2011.
  1. razor10
    razor10 Member
    recently tried installing the radio shack siren on my 02 ultra when i set the alarm get a short buzz sound and when i shake it i get 1 short blast from the siren wondering has anyone did this install on a 02 ultra and ifso did it work
  2. Hoople
    Hoople Account Removed
    7,198
    34
    When you shake the siren itself you get a short blast? That should not be. Did you happen to test the siren itself before installing it by clipping it across a battery just to see if it blows? Almost sounds like a defective siren module or bad connection to the HD wiring harness..
  3. razor10
    razor10 Member
    siren works fine i actually have 2 sirens both function properly when i shake the bike i get 1 short blast
  4. Redfish-Joe
    Redfish-Joe Senior Member
    2,307
    10
    Did it on my 08 and my buds 09. no problems.
  5. nvsteve
    nvsteve Member
    76
    I've had them on 2 bikes and they work fine.
    Are you sure you have the wires in correctly? If installed wrong something similar to what you posted can happen.
  6. razor10
    razor10 Member
    yeah red to brown and black to green my brother-in-law tried it on his 04 road glide has the same problem does the security system have to be set in a ceartain mode
  7. lorne
    lorne Senior Member
    2,428
    58
    22
    loose ground???
