race turner/power commander/or something else
Discussion in 'Touring Models' started by SPH100, Jul 7, 2009.
  1. SPH100
    SPH100 New Member
    3
    Just took delivery of my new 09 ultra. Wondering what would be best to but on. The race turner/ power commander /or something else. I do alot of 2 up riding, I am not looking to race, just wanting good solid power and reliabilty. Ride alot in the smokey mountains of NC and VA. Or would I be just fine with the stage 1 air kit.
  2. Bud White
    3,270
    you will get alot of opinions
    TFI works well till ya go true duals then it wouldnt hold a tune for me
    I have a power commander III reason i went with it vs Harleys race tuner i coudl tune it at home with out the dyno run and a bunch of other stuff
    They say the 09 is more tolerant of air cleaner changes and slip ons but i wouldnt push my luck
  3. 03classic
    03classic Junior Member
    424
    Race tuner is the way to go.I have 03 classic with tru duals and SE air filter.I had nothing but problems with the PC III .I had the race tuner installed and it runs like a new bike,even sounds different.I have great throttle response.I had them run a custom map and gained 10 horespower.I ride 2 up and the HP gain has helped.With anew bike if you want to keep it in warranty that would be my suggestion.
  4. STEVE07
    4,125
    68
    84
  5. Moucheter
    Moucheter Member
    45
    Like BudWhite said, the PC III can be fine tune easily in the confort of your home. For the 2009 it is the PC V. I just install the PC III on my RK last week and it is running perfectly.
  6. The4opps1
    The4opps1 Junior Member
    646
    3
    As was pointed out, ask ten people and you will get ten different answers to this question. I went with a TFI unit when I did the roller chain conversion on my '99 Ultra. I added a set of Andrews 26N cams and a Ness Big Sucker air cleaner to the V&H slip ons that I already had. The TFi unit is just what I was looking for. Not too expensive, relatively easy install, good customer support, and the performance results are very good.
