question on heel toe shifter!!
Discussion in 'Touring Models' started by raparicio, Jan 31, 2010.
  1. raparicio
    raparicio Member
    7
    i have a 1995 road king flhr with only the toe shifter right now. i want to upgrade to a heel toe shifter, i can get my hands one a heel toe shifter off of a 2005 road king. will this 05 shifter bolt onto my 95 road king? anybody know?
  2. ultrat
    ultrat Senior Member Contributor
    1,315
    im thinkin it will;;;
  3. Chopper
    Chopper Senior Member
    1,632
    19
    I think 1988 to present are all the same.
  4. Mattman4403
    Mattman4403 Junior Member
    602
    It should fit. If you have a big foot, look at Walters workshop for some overlength shift arms.
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I thought they ALL came with the heel toe shifter?
    On my FLHR 09, I removed the rear shift lever and put a chrome cap over the shaft stub.
    comparing and LOOKING at the shift levers while off , they are the same and will fit either front ways or back ways..../ I like the TOE ONLY shifting...
    maybe your shaft ISN"T long enough if only ONE shifter is on it now or is there ROOM for two.. OR IS there a cover CAP in place on the outside one?.
    It may be the older models had a ONE PIECE UNIT front AND back on ONE shaft connector? and in that case it should be available as a HD part...
  6. gusotto
    gusotto Junior Member
    604
    38
    13
    I replaced the heel shifter with the Harley folding heel shifter PN 33876-07. ($69.95)
    Gives me plenty of room and still able to heel/toe shift.
    Keeps the boots scuff-free.
  7. murf
    murf Active Member
    322
    I just saw a setup in one of my bike rags for a shifter setup with both up/down levers placed in forward position placed more or less side by side but one peg higher than the other and offset to the side. Looked pretty cool and would seem to work well. Simply step on one lever or the other for up/down instead of heel/toe. Couldn't find the add in my mag again but someone else may also have seen it.
